Originally Posted by bados
Also, I think another difference between the 180 light and HO is that the HO has larger injectors.
All injectors in both the
180hp and the
220/230hp engines are the same after 2003, the
'03 turbo engine was only 215hp and had 47.4 lb/hr =
524.7 cc/min,
(There was no "lite" turbo in '03), The '03 Stage 1 kit, and all 2004 and up turbos have 52.2 lb/hr =
577.1 cc/min injectors, the only difference
is PCM programming, all other parts in the 180 & 220/230hp engines are the same, other than the late '05 & up 230hp engines have the newer composite intake manifold.
