Old 31 Jul 2008, 04:47 pm
Candyman's Avatar
Candyman Candyman is offline
Exclamation Detailing Your Paint: Polishing
Hello Everyone,
Welcome to our next segment in our Guise to Detailing your PT like a Pro!
Many detailers' overlook polishing due to the extra time involved, but if you want to perform a true detail I usually recommend this step. Polish is similar to compound, but contains a much more refined form of micro-abrasive that will help better reduce the Micro scratching left by compounding which will result in more gloss.
Though you can perform this task by hand, for best results I recommend using a rotary buffer.. If you use a rotary buffer, I recommend using a foam polishing pad. These foam pads are available at Automotive Paint Supply Stores, and are specifically engineered to maximize the gloss on your PT.
For this segment, I will be using Meguire's #9 Swirl Remover. This is a good polish, that is inexpensive ($10.00), is available at most PEP BOYS, NAPA, and is simple to use.
For this segment, I am using a Dewalt 849 and a white cool foam polishing pad. As an extra step, I spray a light mist of Meguire's Final Detailer directly yo the pad to help lubricate during the polishing process.
Start by applying a ring of swirl remover to the foam pad. Begin at the top of the vehicle, and work your way down. Like the compound segment, spread the chemical across the panal you are working on, to minimize splatter. Use either the cross hatch pattern, or the figure eight pattern discussed in part 3 of this segment. Proceed over each panal until the exterior is polished, and good gloss is achieved. Be sure to wipe off any left over residue with a clean microfiber towel folded into four and misted with Meguire's Final Inspection, or Meguire's Quick Detailer.
I hope you enjoy my Tutorial's, and thank you very much for reading my Guide to Automotive Detailing! Till next time, take it easy, and we will see you a little further down the road!
For more great information on Professional Automotive Detailing, please check out:
Company & Forum Announcements - Car Care Forums: Meguiar's Online
Or check out our Meguiar's Inside man and Custom PT Owner Michael Stoops for the latest deals on all your Detailing Chemical questions, or needs and be sure to tell them the Candyman sent you!
Michael Stoops
Surface Care Specialist
Meguiar's Inc.
(800) 347-5700 xt 175
mstoops@meguiars.com
Candyman
