Old 01 Aug 2008, 06:28 am
Candyman's Avatar
Candyman Candyman is offline
Exclamation Re: Detailing Your Paint: Waxing
MORE INTERESTING FACTS:
Why should you Wax Your PT?
Predating the automobile, it was European coach builders that first applied coatings of animal fats and wax to protect the custom paintwork on their horse drawn carriages. This tradition has endured over 100 years and is still the best way to protect the paintwork on modern-day coaches. Today, the multi-layered finish on your car, from the primer through the top (clear) coat, is only .006 to .008 of an inch thick. Regardless of how fine the finish is now, it will deteriorate and dull. Radiant and ultraviolet energy, acid rain, salt, atmospheric pollution, insect fluids, and bird droppings wage a constant war on your car’s finish. Waxing provides an easily renewable, transparent barrier between the finish and a hostile environment.
Waxing also makes your car, new or old, look better. Quality waxes now combine enriching oils that “wet” the surface with Brazilian Carnauba Wax and/or modern polymers for a high gloss shine. This brings us to the subject of selecting a wax. Waxes can be made from a natural wax, usually Brazilian Carnauba, or synthetically made with polymers and acrylic resins. In choosing a wax, here are some points to consider:
Carnauba Waxes
Carnauba comes from the fronds of the “Tree of Life” (Copernica Cerifera) native to northern Brazil. It is nature’s hardest, purest, and most transparent wax. Carnauba car waxes tend to produce a deeper, darker, richer shine that is often described as “three-dimensional”.
Many enthusiasts and show-car owners prefer the shine of carnauba waxes, especially on black, red, and dark color cars. Carnauba waxes bead water nicely, absorb the acid content in rain and hide minor swirls in the paint.
On the minus side, carnauba waxes are not as durable as synthetic waxes. Depending on your climate, they typically last 90 days. (Paste carnauba waxes will outlast liquid carnauba waxes due to their higher wax content.) Some carnauba waxes are a little harder to apply and buff off. And, carnauba waxes can be temperamental, sometimes “streaking” under certain temperature conditions.
Synthetic Waxes
Made from modern polymers and acrylic resins, synthetic waxes offer maximum durability and ease of application. Synthetic waxes can last six to nine months or longer and typically wipe on and buff off with very little effort. These waxes, sometimes called sealants, create a very bright shine and are resistant to clouding and streaking.
On the down side, many enthusiasts feel synthetic waxes lack depth and richness. Black cars can look a sterile silvery-white in direct sunlight. And, the mirror-like polymers can collect in minor swirls and actually highlight paint flaws.
One-Step Cleaner/Waxes
Many brands of carnauba and synthetic waxes can be purchased with or without cleaning agents. If you are using a polish before you wax, select a “pure” wax without cleaners. These formulas should produce a higher gloss and last longer. If you cannot devote the extra time for separate polishing, select a one-step cleaner/wax. One-step waxes can do an excellent job of maintaining newer finishes but cannot restore older cars with dull, oxidized, or neglected paint.
How long will wax last?
Many enthusiasts prefer the shine from Carnauba waxes. It is a deeper, richer shine and tends to mask and hide minor swirls in the paint. While Caranuba has the highest melting point of all natural waxes it does start to melt at 180 degrees F. A dark color vehicle parked in the sun on a summer day can have a sustained paint temperature exceeding 200 degrees f!
A good rule of thumb is to expect 50% of your Carnauba wax layer to be gone after 30 days, 75% after 60 days and 95% gone after 90 days. If you use a carnauba wax, you should plan on waxing your car four (4) times a year. You can extend the waxes life expectancy by parking indoors, using a car cover and by using spray-and-wipe detail sprays like Meguiar's Quick Detailer.
Synthetic waxes contain man made polymers with melting points in the thousands of degrees F. These coatings can last 6 to 9 months or longer. Some of these products bead water while others “plate” the surface causing water to sheet off. This lack of a visual cue (beading water) often makes it difficult to determine when to re-apply synthetic products. a good rule is to wax your car once in the spring and again late fall. This should give your car good protection all year long.
I hope you enjoy my Tutorial's, and thank you very much for reading my Guide to Automotive Detailing! Till next time, take it easy, and we will see you a little further down the road!
For more great information on Professional Automotive Detailing, please check out:
Company & Forum Announcements - Car Care Forums: Meguiar's Online
Or check out our Meguiar's Inside man and Custom PT Owner Michael Stoops for the latest deals on all your Detailing Chemical questions, or needs and be sure to tell them the Candyman sent you!
Michael Stoops
Surface Care Specialist
Meguiar's Inc.
(800) 347-5700 xt 175
mstoops@meguiars.com
Candyman
