Old 07 Aug 2008, 03:19 am
Candyman's Avatar
Candyman Candyman is offline
Smile Re: New Custom PT Parts?
Hey TeaHead,
I have to get a few measurements, but should be no problem! The only catch we might have at the moment is that since we are focusing on Bike Mirrors for the most part, at the moment, I can't seem to locate power adjustable mirrors. They do make power dimming, and Digital LED Turn Signal Mirrors with the signal showing through the mirror, but nothing adjustable at the moment. I will keep looking as I am sure that this will become an important topic as we develop this idea!
To give you a better idea of our concept we are shooting for, The mirrors on the hardtop (as should be similar on the Vert) are just one piece units held in place by three bolts. Their is an after market replacement mirror available now that uses a flat looking mounting plate which uses the same three bolt locations for mounting, and has a small round mirror, and stem attached to it. While that is great, and all, the mounting plate is made from a lightweight fiberglass, or plastic material, and lets say, you don't like that round mirror, and would like a different design. Well, your out of luck because that round mirror is part of the whole assembly. I myself would rather have a few options to display my own vision, and custom touch!
Here is a couple of links to a website that has a pretty good selection of mirrors like the ones we would like to incorporate into our design. Every mirror is held on by one bolt, and nut which would attach to a metal, or aluminum mounting plate that would in return match up to the three bolts for the stock assembly. That would allow you to pick, and change mirrors all day long by simply loosening a couple of nuts! Here are the Links:
Flame Harley Davidson V-Rod Mirrors
Custom Harley Mirrors, Chrome And Black Motorcycle Mirrors
Those are just a couple of examples, but if you do a Google Search on Motorcycle Mirrors, their are thousands, and they all will fit our brackets, leaving you thousands of new possibilities for customizing your PT! Whats even better is when you start looking at these bike mirrors, most of them have cost range of $120.00 - $240, depending on how fancy you want to go. without even running the numbers you will easily save between $80.00 to $1oo.oo off of the cost for the alternative mirrors, and get a better product that was not punched out on an assembly line, but rather custom made by hand to fit your car!! And with that kind of savings, you could afford to custom paint your brackets, or even have them chromed if you like! Were here to make what you want, how you want it, and when you want it!
Please let me know if you might be interested, and I can get some more information on the specifics tha you are looking for so I can get you a great price! Thank you, and take it easy!
Candyman
