Old 10 Aug 2008, 03:15 pm
lanies_ptcruiser02 lanies_ptcruiser02 is offline
Unhappy loose timing belt and gears not moving - urgently need help pls.
Hi...I need some help pls! I have a 2002 PT Cruiser 2.4L , just over 1000K.
No problems since I have owned it (1yr, I am second owner). Other than not running as clean as it had been. I was going to get it tuned up next week.
I was driving onto the highway the other day and it just lost power, the engine stopped running. Just before it completely stopped, the check engine light and oil light came on and have stayed on since. I tried to crank it, but had to have it towed home.
I got an error code P0340. My boyfriend took a peek into the timing belt compartment and the belt is very loose. We tried to crank it while he looked to see if the timing belt was moving, neither the belt of the gears are moving.
Someone told me that the PT has an "interference engine", and that if the timing belt stopped working and we tried to crank it then it would warp the pistons.....Is this true?
