Old 10 Aug 2008, 04:54 pm
CREWZIN CREWZIN is offline
Default Re: loose timing belt and gears not moving - urgently need help pls.
Well, my diagnoses (wild guess) was the timing belt because of what you said your boyfriend saw when you cranked the engine.
The code P0340 of the camshaft position sensor will also bring the car to a halt. I know that for a fact because it went on me while I was on cruise control at 80mph going through South Carolina. Believe me, when I say the PT comes to a real fast slow down and the power steering shuts off and it ain't no fun. 11pm at night no less. Thank the Lord for cell phones.
The timing belt won't give a fault code and I'm not sure that when, and if, the timing belt goes and the engine stops, that won't trigger other codes like the P0340 because everything stops.
Hopefully one of out mechanics on the forum will come along and clear that up. The Camshaft sensor is a lot less expensive and easier to replace so lets hope it's that.
