Old 13 Aug 2008, 02:14 pm
nevinsrt's Avatar
nevinsrt nevinsrt is offline
Default Re: Custom PT Cruiser 4x4
wow thats just too weird. and different.
paint it black, green and purple then call it
mini Grave digger!!!
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
