Old 15 Aug 2008, 03:13 pm
Cal Cruzer Cal Cruzer is offline
Default Re: plastic manifold & stage 1
Originally Posted by Taggert_LOA View Post
Lest we forget to mention to pull the fuel pressure fuse out of the engine fuse box and then kick the motor over till it stalls. then remove the fuel injectors. you pull them out while under pressure, your likely to either blind yourself or get fuel all over your paint and damage your headlights with fuel spill.
Nah, there is very little volumn in the fuel rail. As soon as you release the pressure via the small valve on the end of the rail you won't have any problems. Just hold a paper towel under it when you push the release, it will just be a small squirt at worst. Pressure may even be nill if the car has sat for a while. That is why you hear the fuel pump whir a little when you turn the key in the ignition. It looses some pressure over time.
