The Crank position sensor won't work with the controller. I used the Ignition coil #1 cable and set up the controller as a two CYL engine. The controller operates by reading the pulses to the ignition and our cars have two coils. It is the Black cable and gray line on the orange connector (I will check the manual and confirm the colors and connector) It works perfect! I am still working with the vehicle speed sensor. My PT is equiped with the A/S trany. The manual one has a speed sensor. Hector, see if it works with your controller.
