Originally Posted by outfit
okay found the 4410's for the front dome and the Lic plate one , but can't find the one for the rear dome the TS-579.- 921..did you use the festoon bulb type if so which one was it ??
The rear dome light is tricky, it is not a festoon (tube) type bulb, its a wedge!
921!
consider wide angle LED's if they have them, and when you install them use some aluminum foil directly across from the beam the LED creates, it helps deflect the light!
