Old 01 Sep 2008, 01:46 pm
yaschief's Avatar
yaschief yaschief is offline
Default Re: Cleanign 06' Canvas Seats
I just did a shampoo job on the grey cloth front seats on my 07 TC and used Blue Coral Spray Upholstry Cleaner. (Autozone/PepBoyz/Kragen/Oreilly's)
I first pretreated the spots with the spray foam and worked the foam in to the areas with a 4 in nylon bristle hand brush using normal pressure. Wiped with a damp cloth towel and then sprayed the whole seat and did the same cleaning using a hand brush with a pattern that went with and then across the grain to lift the dirt and foam. When I was done I rinsed the brush and went over it again with a second treatment. Wiped with a damp cloth and then used an absorbent Shamwow to suck up the residual cleaning foam and when dry vacuumed with a floor nozzle (6 in wide pattern). I had both coffee and soda on my seat due to a passenger who is a pig. (Thanks Chuck you dip). Results were all the spots came out. Ypu shoudl do the entire seat so if there is a slight color or tone shift when it drys the whole seat will match.
Now I remember that some years were treated with a special fabric agent but I cannot remember which years.
I will do a treatment of Scotchgard after they dry for 48 hours in an attempt to "Chuckproof" the seats.[
Hope this helped.
QUOTE=Cathy06PT;240378]I have 2 stains on my passenger seat and can't get them out...Other then professional detailing, what's the best way to clean the canvas seats because some aftermarket products leave worse stains on the canvas material then what was already there! [/QUOTE]
