Old 02 Sep 2008, 08:15 pm
icezebra icezebra is offline
Default Re: Impending turbo doom, or just a clogged oil return line causing whine and smoke?
Gentlemen,
You are both correct. Thank-you for your expert analysis. The unit has been replaced by Chrysler under warrranty. Now here is the kicker. It wasn't the dino oil (yes I will use synth now, I already got the lecture) it was the sludge which plugged the coolant line.
Here is a disturbing factoid: The long life coolant turns to sludge as water boils off via a leaky rad cap (which I may or may not have, plan to flush coolant this weekend).
More details here:
Better photo:
PTCrew.com - Learn it or Burn it.
Replacement options:
The poop on the rad fluid:
