Thread: EGR Valve
Old 07 Sep 2008, 10:47 am
2k1PT 2k1PT is offline
Default Re: EGR Valve
I can tell you that to get to it, you will need to pull out all the air related units (air filter, air filter box, hose, etc.) and then pull the batt.
That should give you ample room to see what you are looking for.
I ahve not replaced mine yet, but I have the exact same code, and I just havent gotten around to getting a replacement yet. Its about $100.
However I have gotten to it when I had to replace the spark plugs so I know where its at. When you get everything out the EGR valve will be lower front, and then a silver tube will go back and arounf the engine, to the top back.
Just so you know, I have driven around on it got about 8 months now. It wont damage the car, just might make for crummey gas milage.
