Old 08 Sep 2008, 10:44 pm
lakersfan1 lakersfan1 is offline
Default Re: Dead Battery???? I think not...
It is possible I suppose. If it happens again though .... first culprit I usually have is bad grounds. I will just start replacing ground wires with large gauge wire with platinum terminals. Then, I will usually also replace the alternator-to-battery power wire also with large wire with platinum terminals. This will help you rule out bad connections as a culprit .... which more times than not is at least a hinderance on cars that have seen at least a few harsh winters.
