Re: Strange problem...
Go out to your PT right now and check the brake fluid level in the reservoir. Odds are that your low in fluid. There's a sensor somewhere in the container and when you take off from a stop the fluid is pushed back against the side and the sensor thinks/knows your low in brake fluid. It then sends a signal to turn the brake light on to let you know.
