Old 11 Sep 2008, 09:42 am
teknoron teknoron is offline
Default Pt Cruiser Not Starting
Ok in a nutshell, I came home from work, went into the house and came back out, bout 5 min time. The car would not start; it would turn over but not catch. I can see the alternator and ac belts turn so I ruled out timing belt. Code p 0340 so I looked it up on this site and went ahead and replaced the Cam position sensor. Still the same issue almost like it is getting no spark, except from time to time I get a little bump from the engine like it is trying to start but few and far between. The only other code that shows is a p 1684, but that came up as a disconnected battery, which I did replace the battery. Any other suggestions????
