Old 13 Sep 2008, 01:30 pm
Deano Deano is offline
Default Re: When it rains, it pours...
Originally Posted by CREWZIN View Post
If your talking about the bolt that holds the cable end tight around the battery post, You should be able to use any bolt that holds it tight. It's the cable end itself that transfers the power or grounds the battery.
That nasty stuff your seeing seems to be quite prominent on a lot of cruisers. A lot of talk on the forum about it.
Make sure you clean everything up good before putting the cable back on.
Yup, that's the one.
Does it sound like the battery needs to be replaced, too? The thing about it is we went to the park the day before and it started and ran fine.
Forgot to add that I jumped it and it fired right up. Shut it off and back to the clickclickclick.
