Old 13 Sep 2008, 08:07 pm
Dirk_Gently's Avatar
Dirk_Gently Dirk_Gently is offline
Default Re: Tuning with SCT?
Originally Posted by bobs turbo pt View Post
what is sct ??
SCT Automotive Performance Products
SCT is a company that provides tuning equipment. Like Super Chips, or Diablo Chips...etc The most useful of which (I think) is their hand held tuning device XCALIBRATOR. They are up to XCALIII I think. Basically, it plugs into your OBDII port and allows you to reflash your PCMs settings. So that way you can adjust your tune - raise rev limit, change timing, remove\change speed limiter, adjust fuel curves...etc without needing a piggy back unit. The system stores your original "stock" tune so that you can flash back to stock anytime you want. With a good tuner and some dyno time you can see some pretty significant gains. Ford has had SCT product available for years, but DCX has not been as useful. A year or so ago SCT added the SRT-4 as a tunable PCM and since the PTGT uses basically the same one it should be good to go I think.
Wait wait wait, if "boost gets your laid" how come all you get is shaft play?
