Old 14 Sep 2008, 01:25 pm
CREWZIN CREWZIN is offline
Default Re: My PT is Choking!!!
Originally Posted by nasteven View Post
, I experiened when I got on the paved road that my engine light went of...then my car started like choking and it just wanted to die..but, it kept chugging until I had to pull over, rather than get rear ended.
Welcome to the forum. I can't quite make out if you saw the "check engine" light or not. If you did, do you know how to pull the code from the computer? That will help or guide us toward an answer to your problems.
That 1 acre of soft dirt, if you kicked it around a lot, could have gotten places that did some damage but might have just clogged your air filter. Did you check the filter to see how clean it was?
Was it just a guess about the fuel filter on your part or did someone tell you something you haven't told us?
Do you have the turbo engine or non-turbo?
