Old 17 Sep 2003, 04:14 pm
skylight's Avatar
skylight skylight is offline
Administrator
Default Replaced under Warranty - PCM and Rack & Pinion
Just got my rack & pinion replaced under warranty for the squeeling/rubbing noise (sounds kinda like when you pull the seat belt out quickly back and forth). The noise is not there anymore. They also did an alignment (warrantied of course).
They also replaced my PCM for the 5200RPM misfires (there's a TSB for it). No more misfire. The AutoStick shifts more smoothly now thru all gears ...most notably that 2-1 whiplashing downshift isn't as harsh anymore. When I pulled out of the dealership, I noticed the speedometer wasn't moving so I turned around, told the technician and he quickly did a "reset" and the speedo now works fine.
Thanks to everyone in here for sharing your experiences, it made my experience easier with the service department.
[8][|)]
