Thread: cluster lights
Old 17 Sep 2008, 07:23 pm
Duster's Avatar
Duster Duster is offline
Default Re: cluster lights
Originally Posted by Hooligan View Post
chips61, not sure what you mean by the term "cluster lights". If you are refering to the High Center Mounted Brake Light, you can remove the cover by gripping near one end and pulling straight down (with the hatch cover open) there are 5 clips that hold the cover on. Just keep pulling until the whole piece comes loose. Good Luck!!
No pun intended but I'm not sure myself what you are thinking about. Center brake light?!
It seems clear to me that chips61 wants to change a dead light behind the instrument cluster.
I can't talk for the 2006+ models, but here are the instructions for the 2005- cluster.
Edit: Too big for attachment option. Click on the following links instead
Cluster Removal
Cluster Lamps
