Thread: Problems!
Old 17 Sep 2008, 09:03 pm
CREWZIN CREWZIN is offline
Default Re: Problems!
Well, 2 things. First, when you stall the power assisted brakes no longer work and that's why the pedal gets hard so nothings wrong there. 2nd, one of the engine modules like the PCM (Power Control Module) or ECM (Engine Control Module) or ECU (Electronic Control Unit) the does controlling through sensors to adjust the idle so it won't stall when you come to a stop or turn the A/C on, so you might have a problem with one of them.
