Thread: Oil Light
Old 20 Sep 2008, 10:46 am
nalati's Avatar
nalati nalati is offline
Default Oil Light
First time user, from Gilbert Arizona, I’m a home Inspector and travel a lot with my 04 Cruiser. She has just under 59K on her now and my mechanic is scratching his head, Chrysler wants to troubleshoot by replacing components.
My 04 sometimes gets a Intermittent Oil Light!
First time the light came on I was (PT) Cruising down the high way at about 65MPH, I got the Dong, dong noise, looked at the interment panel and had the oil light. Pulled over, turned off the car and checked the oil lever (level was ok). Started the car, light never came back on, had oil changed. For about 3 month everything was fine, then sitting at a red light the oil light came on once more. I turned off the car, light turned green and I started her up and pulled off the road. Oil level was fine, Changed the oil my self this time. On a different Forum someone mentioned using the 2.4 Turbo Oil filter (Filter is larger and filters more stuff), so I did. For the next month or so everything was fine until yesterday, oil light came on after about 25 miles of surface driving, I was going about 25 MPH and the light came on, pulled over and turned off the car, started her up, light stayed off and I took off. About 5 minuets latter the light came on at a Stop light, turned her off until the light turned green and pulled into a parking lot, checked the oil level and once more it was fine.
I try to change the oil between 3500 and 4K, I normally use Straight 40 weight Pennzoil, now I have been using 20 / 50. Check the Error code and there are none.
Any thoughts
