Thread: stuck valve
Old 23 Sep 2008, 12:34 am
cleverklutz cleverklutz is offline
Default Re: stuck valve
Wow, I guess everything I own should be in tip top shape! Since my PT is a gutless wonder, it sees about 500rpm away from redline for each shift quite often (achieved by about half throttle, full throttle just makes more noise and gives about the same acceleration...). Oh well... That's the drawback of having a n/a slushbox.
On the missing side of things, you've probably already found it on the forum here, but there's a tsb for regapping the plugs to .040". Stock is .052". That has fixed many peoples problems with rough running. I still have to try that on mine since it's running quite poorly now.
Ben
2001 Red PT Cruiser Limited, 16" OEM alloys, Airaid CAI, Screamin' Demon coil and Livewires, some shiny stuff inside, Alpine deck, Alpine four channel amp, Alpine PLT5 sub, Hertz speakers in 4 corners, Keystone ram air hood, 6000k 55w HID high beams, 6000k 35w HID fog lights, new stone chips every day to add character.
2007 Suzuki King Quad 700 4x4 for when the road gets bumpy.
