Thread
Light reflection?
2
permalink
29 May 2003, 04:55 pm
Gear_Head
Gear_Head's Gallery
TurbomanGT, If you're looking for reflective tape, go to a plumbing/heating supply store and putchase a roll of Aluminum furnace tape. It can be polished, or you can cover it with chrome tape (pep boys) used for auto rocker panels. The furnace tape can be purchased in any width and it is actually metal. It should also withstand the heat without any problem. (i'm not sure about the chrome tape being able to take the heat though). I needed an indicator light for the 2nd stage boost switch. I bought a blue 7 led scanner. and mounted it on the steering column facing the dash. Wired it so its on when the boost switch is on. Used a piece of aluminum furnace tape covered by chrome tape and made a reflector below the speedometer on the instrument cover. Looks great You can see the reflected light bit you cannot see the scanner itself
Gear_Head
View Public Profile
Visit Gear_Head's homepage!
Find all posts by Gear_Head
