Re: CPS Error Code
The newbie here again. I tried clearing the code after replacing the the camshaft position sensor per the code 340. Did not work. Once I hit about 2000 rpm I still get the cut out and now get now get code 344 (this started basically instantly. I originally didi not have this code). I am at a loss. In the family we have a custom 01 tricked out normally aspirated and a 05 GT convert. Both have no problems other than the 01 that was fixed with boogar bushings. I did check the odometer and it is at 69,250 exactly. Should I just put it in service?
