Old 29 Sep 2008, 09:59 am
sqworley sqworley is offline
Default Re: Temporary losing oil pressure
i was suggessted to replace the oils sending unit because it may be leaking around the ring on it. It was leaking and i did replace it but after letting the car idle for 30 minutes no leaks. I drove the car down the road about 3 miles and pulled over and had a steady drip coming from between the engine and transmission area. So now i guess it is the rear main seal leaking but that does not explain the temp losing oil pressure issue. does anyone know what the easiest way is to replace the rear main seal?
