Thread: Oh the failures
Old 30 Sep 2008, 06:50 am
Candyman's Avatar
Candyman Candyman is offline
Smile Re: Oh the failures
Hey Dirk_Gently,
My first question is, since they cleared the computer, have you driven it, or idled it for a length of time, and then rechecked for codes?
A while back, I had my battery completely die on me while in storage. It had a reading of like 4 volts, and wouldn't even turn on the interior lights! Since it is a deep cycle Optima Battery, I quick charged it for a couple hours till it had enough juice, and then ran it around for a bit. I got on it a little to let the engine breathe a little, and apparently a combination of the battery not being fully charged, and my getting on the gas a couple times, it tripped 5 codes by the time I got home, including the Oil Pressure switch, TPS Senser, Air Bag Light, ABS Failure, and so on. I was pretty sure it was a voltage issue, but to be safe, since my mechanic was booked fpr three weeks at the time, I decided to take it to Chrysler to run a computer diagnostic. They immediately said everything was bad and gave me a $870.00 quote to fix it! Out of curiosity, I swung by my mechanic, and asked him real quickly about it. He hooked his laptop up, checked the engine which was fine, cleared the codes, and never had a problem of any kind since!
So you may have had some false codes due to a low battery, and nothing more! If you can recreate the systems again after the codes were cleared, then you know you have a problem! If the codes do not come back, you should most likely be ok!
Anyways, it might give you something to look for! Best of luck!
Candyman
Check out my Custom PT Club Website: http://westvalleyforum.proboards.com/index.cgi
And my ever growing PT Photo Archives: http://s458.photobucket.com/albums/q...uiserArchives/
Got a Question? Drop me a line anytime: westvalleycruisers@yahoo.com
