Thread: code p 1187
Old 01 Oct 2008, 03:34 pm
Dirk_Gently's Avatar
Dirk_Gently Dirk_Gently is offline
Default Re: code p 1187
Originally Posted by shorty68 View Post
What does this mean? p 1187 is this really bad? I was just about to take my Grandma to the beachany help would be really great.
I think P1187 is over boost? Usually part throttle over boost. Means you made more than X psi (I can't remember the number. 5 psi maybe?) without being at WOT (Wide Open Throttle - foot to the floor) Disconnect your negative battery terminal and it will clear the code. See if it happens again. Have you altered the wastegate? Do you have a boost controller?
Wait wait wait, if "boost gets your laid" how come all you get is shaft play?
