Thread: water leaking
Old 01 Oct 2008, 04:33 pm
Teekypt's Avatar
Teekypt Teekypt is offline
Send a message via Skype™ to Teekypt
Default Re: water leaking
Originally Posted by crusierdad76 View Post
Good advise The PT's do seem to drip a lot of water but like already said if it aint green or red your probably safe
however to answer your other questions
with 176xxx if the timing belt hasn't been changed it is LONG way past time Id have somebody that knows something about cars check that probably 1st thing and do the timing belt the water pump and the oil pump while you are there
then maybe a set of wires and plugs make sure the oil is keep changed as ofter as it needs to be---that's a lot of miles on a 4 banger Id for sure go synthetic check the air cleaner I'm probably missing a lot but some body else will jump in
Yeah...176XXXkm is approx 109,361 miles...so yes, you should have your timing belt looked at.
2003, GT, "ShuggaPlum", xenon bumper kit and Accra-Form Running Boards, custom tan/black neoprene seat covers (front & back).
Houston, TX
http://www.math.uh.edu/~tai/Today/Clean3.jpg
