quote:Originally posted by jramosGT
Does the alarm system arm after the TT cuts out? On my '93 RX-7, the alarm did not arm once the TT finished. If I wanted the alarm active, I needed to unlock then lock the doors.
ON the SRt, there is no issues with the stock alarm. The only thing you dont get is the honk when you arm the alarm with the TT running. ON aftermarket alarms system slike the DEI(viper, python, etc.) you car will arm, but then as the TT turns off, the alarm opens the doors. A sharp alarm shop will be able to bypass this by using a simple relay in the ignition area.
E.D. 3\" Turbo Back, , HKS SSBOV, GReddy-e01 Boost controller, Greddy E-manage fuel management, Blitz Turbo Timer, JE pistons, Ported Head, E.D. Large Frontmount Intercooler, E.D. Tubular manifold with t3/t4 (prototype), IPP coilovers, Limited Slip.
