Re: 60k Service (dealer) Fuel system servicing
you can do it yourself if you have the proper hook ups I'm not sure on the PT but on a Silverado Pick Up there is a port r a hookup that will allow the hose to hook up to the rails on the system it is kinda a hook up and spray its a little better than sea foam only because it is under pressure and if there is any yuk on the tips of the injectors it will "SOMETIMES" clean it off---however keep in mind there is only so much pressure you can send thought the system
