Thread: Overheating PT
  #20 (permalink)
Old 04 Oct 2008, 11:31 am
CREWZIN CREWZIN is offline
Default Re: Overheating PT
I'm almost positive the water pump is mechanical so when it fails it fails and either leaks a lot from the front or doesn't let the coolant run around the engine to cool things off so you wouldn't have the times you say it doesn't overheat without the A/C on. It would overheat all the time.
Good luck at the dealer. Make sure yo have them run the engine with the A/C ON to see it overheat. Please come back and let us know if/when they find the problem.
2000 PT. 96K miles, Original Owner
