Old 05 Oct 2008, 04:25 pm
Cruiser_SGT Cruiser_SGT is offline
Default 2003 Turbo Ignition problems
Ok here is the problem. I have recently replaced the coil, wires and plugs along with the cam shaft position sensor. The car ran excellent right after I replaced all of these things. I drove it for about fifteen miles and turned it off for about an hour. I went to go and drive it again after an hour and it started fine but I got out on the street and got on the accelarator the car started to misfire real bad and it would not shift out of 2nd gear and the check engine light was flashing. I immediately took it to the first repair place I could find. They ran a diagnostic on it a and it came back with a misfire on every cylinder. The tech regapped the plugs and the car seemed to run fine again. I thought the problem was fixed. But after I got home and let the car sit for a while the problem started all over again. I took it up to autozone and the codes coming up now are P2305,P0304,P0300,P0128. Didn't think I would have all of these probs just changing these few things.
Spark Plugs Champion OEM with .50 gap
New Wire Set
New Ignition Coil
New Cam Shaft position sensor
