Engine cuts in and out at 2200 RPM
Driving on the freeway after about 20 miles the engine light comes on. At between 2,100 - 2,200 rpm the engine cuts out.
Riding the line between 2,100 and 2,200 rpm is like a bucking bronco as the power cuts in and out.
Drop the speed/rpm to under 2,100 rpm, engine runs fine.
Once the problem starts, anytime you hit between 2,100 and 2,200 rpm the engine cuts out regardless of speed.
Turn off the car, let it sit overnight, problem is gone. For a day or two. Then it happens again.
I took the car to the dealer. They say there are no stored error codes and they can't replicate the problem.
So, I picked up the car after they had "tested" it for 3 days and can't find any problem.
Drive 20 miles and, here we go again. Same problem.
Any ideas?
