Originally Posted by CREWZIN
You don't say how many miles are on your PT.
There's two belts that could be slipping, the serpentine and alternator belt. Either one could be causing the squeak/squeal. The tensioner only works on the serpentine belt and could need changing itself. The alternator itself has to be adjusted to take up the slack of that belt.
I asked your mileage because it could be time to change both belts if your anywhere near 100K.
The PT is about to turn 121k miles old. As you mentioned, it might be time for a new belt/s or the tenstioner. You are right! I will see if the alternator needs to be pushed a bit, and hopefully that will take care of my crying engine.
Originally Posted by BLUEH20
A few yers ago there was an issue tith Cruisers and water/snow. It seems that the belts had a propensity to fall off after hitting a deep puddle or snow berm. Chrysler came out with a snow/water guard for the lower area of belt travel. This item may still be in the system. Need to check aganist your year and motor with a good parts person. Have the Service department look it up under TSB's.
Happing Motoring.
I'm going to look into that. I have seen the both of the belts, and I might fabricate something to keep water, and snow because we get snow too, from splasing up under there. I also need to look too see if it won't overheat, or my engine temps, if I do that.
1999 Corvette and it's mate a 2001 PT Cruiser Limited.
I'm not hard to please.............
..........I just like things my way
