Old 15 Oct 2008, 02:03 pm
opelenvy opelenvy is offline
Send a message via AIM to opelenvy Send a message via Yahoo to opelenvy
Default Bleeding the clutch
My 01 5-speed was having some clutch problems. I diagnosed it to the slave cylinder. I got a Wagner one from Rock Auto and installed it. It does not have the bleeder like the stock one did. The port it there, it is just sealed off in the casting. I called Rock Auto and they called Wagner and they said that it is a factory part and that Chrysler no longer used the bleeder.
He said to fill the cylinder with the rod out. Pump it to make sure it is full. Then hook up hose and install and pump the rod with the cap off to bleed. I did this a LOT. But I cannot get the full motion from the clutch. It only engages maybe 1" and that is not enough to shift.
Any ideas?
Please!
