Re: airbox customizin for a 07 nt
Originally Posted by ptborder
There are several threads on here about that mod. Basically, rip out the white plastic silencer that you see when you lift the top off of the box....no performance increase, just a little more of that waaaaa....sound. Other guys talk about filling the pie shaped piece with foam etc....best bet is a drop in K&N filter to start with imo.
If the 07 airbox is the same as the 01-05, then this is mostly correct. You remove both the snorkels (white and black) then you fill the front silencer section with expanding foam etc. I just did it about a week ago and its louder, but not "waaaaa." That combined with a drop in K&N will give you a nice little added pep.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
