Old 02 Jun 2003, 02:03 pm
Stephen R. Stephen R. is offline
I'm running 18x7.5 +35mm offset with 235/40 tires. From the looks of things, I'd say you could maybe go to a +25mm to get the wide trak look. Consider that a RWD wheel is around 0mm stock to a negative offset for deep dish. A potential problem though may be caliper clearance, too.
If you really want the dished rim look, check http://store1.yimg.com/I/speedandstyle_1743_289480 and http://www.streetstyler.com/ArospeedChaosWheels.htm I believe this wheel has a 360-degree machined lip behind the spokes!
