Old 25 Oct 2008, 04:30 pm
ftkbcw ftkbcw is offline
Default Re: how to remove cranksensor
The "structural collar" is nothing more then a pin that holds the connector together. They can be difficult to remove. If you break the pin don't worry as long as it snaps back together. Also, check to see if the wiring harness is rubbing the axle shaft. The plastic connector that holds it in place can break and the harness falls against the axle rubbing the harness into (or some of the wires)
