Thread: check eng light
Old 29 Oct 2008, 12:24 pm
CREWZIN CREWZIN is offline
Default Re: check eng light
Originally Posted by PPTCruiserTE View Post
My check engine light came on for a short time at a cold start, I switched it into park, gunned the engine and it didn't shut off. But it may have that problem your talking about, because it idles rough and I can hear the power steering sound coming out of it (I am a total novice about cars, but my father was a master mechanic in the old days so I can learn; I am not afraid)
Also is it true with the new gas with ethanol they have out that if you mix 2 cycle oil with gas it will improve the performance and mileage because the ethanol gas lacks lubricant?
If you had the Check engine light, the computer stored a code that would help us track down the problem. Read around the forum for the explanation on how to read the computer and let us know the code that is stored.
Ethanol is added to the fuel supposedly to save money on making it. If it is low on lubricants, the other 90% of the gasoline will have enough for the engine. Do you have the link to the information on adding 2 cycle oil?
