Re: Rear Window Noise
The rear 1/4 windows have a slight rattle. If you push out on them the nnoise stops. You can use a good quality silicone lube on the rubbers, solves about 10% of the problem the rest the window has to be "tipped out" at the top. The window has to be adjusted out wards. A good tech can do this in about 1/2 hour per window. We do it all the time.
