Thread: Custom Intake
Old 31 Oct 2008, 03:42 pm
Mean Green Mean Green is offline
Default Re: Custom Intake
Originally Posted by Hitman9853 View Post
do you have any idea of the size of the pipe from the turbo and angels needed.
Go here. Reinforced Silicone Couplers: Silicone Hump Hose, Silicone Reducers (Silicone Transition Hose or Step Hose), Silicone Elbows, Silicone Straight Hose : BoostController.com LLC - America's Source for High quality turbo boost controllers, silicone hose,
You'll need one of these 3" reduced to 2 1/2" #ASRE90-X. Silicone Reducing Elbow - 90 degrees and one of these 3" X 3" couplers #ASCSH3-X. Silicone Straight Hose - 3 inch length
For the 3" pipe you could use some 3" exhaust pipe and paint it the color of your choice.
You will need to add a nipple to the pipe for a vacuum hose. For the nipple you could use a rubber valve core to attach the vacuum hose to. Cut a hole in the pipe and slip the valve core through the hole.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
