Old 11 Nov 2008, 02:35 pm
CREWZIN CREWZIN is offline
Default Re: 2001 pt cruise control problems
From the Haynes manual:
The system consists of the PCM, Vacuum servo, brake switch, control switches and vehicle speed sensor. Some features of the system require special testers and diagnostic procedures.
checking:
fuses, brake light voltage (voltage from the brake light switch deactivates the cruise control), Visually inspect the control cable between the servo and the throttle linkage for free movement, vehicle speed sensor (dealer tested).
