  #18 (permalink)
Old 03 Jun 2003, 10:32 pm
amx1397 amx1397 is offline
LOSE THAT ENG BOG: If you have a boost controller and it is set about 15 when the eng is cold you have to baby it right? Not any more,(at least it works for me), O the inlet air hose to the throdle body there is the air temp probe and the boost line it is the hard plastic part of the hose on top of the engine. if u have a boost controller then disconnect that line lay it aside , u don't have to plug either side, the boost will go as high as you have the controller set plus some, as long as you floor the gas no bog, if u are going 35mph and slowly increase to 50 mph the boost will go up to fast and stay up and go to high and the car will bog. go fast no bog. go slow you get bog. try it and let me know if your car does the same I see it as FREE POWER amx1397@aol.com jim
jim
