Re: engine washing
- Warm the engine up, then kill it.
- Use aluminum foil to cover any parts you don't want wet (fuse block, relays, whatever).
- Spray the engine compartment with engine cleaner (the foaming kind in a can...can pick up at Walmart or any parts store). This is petroleum based, but I would try to avoid getting it on the fenders when spraying...it would spot or streak the finish....not permanently but you may have to touch up the wax.
- Wait 5-10 minutes
- Using a garden hose, spray off the engine compartment
- Remove the aluminum foil
- Start engine up
- Let it run for a good 10 minutes - this will ensure water didn't get down in any places you don't want AND will help dry the engine.
- You can also use an air compressor with a blower nozzle to aid the drying process.
- Once dry, I spray the entire compartment with WD-40. There are several "engine dress" sprays available, but I've always liked the results of the WD-40 and it's cheaper!
- Since WD-40 has a tendency to create over spray I usually do this process when I'm about to wash the car.
- I'm a bit anal and actually wash my engine everytime the car is washed!
- Once WD-40 is applied, use a shop towel to wipe down everything. It will leave a nice glossy look without having a wet residue everywhere.
Tim
Little Rock, AR
'05 PT Convertible
'03 S500
'98 SL500
