  #23 (permalink)
Old 04 Jun 2003, 06:44 am
hyracer hyracer is offline
Don668,
I believe Exhaust Depot is refering to boost in first gear only. On my 5-spd my boost gage needle moves between 5-7 lbs. boost in first gear. Once 2nd or higher gear is engaged the boost will climb up to a maximum of 13 lbs. boost, but others are claiming they are reaching 14 lbs. maximum with the stock factory setup.
Deen
