Re: CAMBER ADJUSTER KITS
I'm sure that the only front camber adjusters are the cam bolts. Rear can only be adjusted by shims. Most shims are a stock item at front end shops. They have an array of different thicknesses. I have seen an adjustable shim, but can't find the source. The shims are usually cut so they can be installed without disassembling the brakes. I would still love to know if the drum and disc rear brake take different shims.
