Old 11 Dec 2008, 10:28 pm
Default Re: CAMBER ADJUSTER KIT
I can only comment that you are correct - rear is shims - I have rear disks and that's the adjustment. I needed a rear alignment not from lowering, but because of a nasty pothole. The eccentric amber bolts are for the front, and many have said they didn't need them, the more you lower, the more likely you'll need it.
