Re: intake manifold???
Are you attempting to install the turbo on a factory N/A engine? There are probably a few more things you will need such as the pcm. Also the factory turbo engine is not exactly the same as the N/A engine, example the extra oilers on the turbo. I would do a lot of research before attempting this.
The intake manifold you are referring to is the intercooler piping. N/A PT pipe will not work.
 2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
